Epson Stylus R1900 keeps blowing F1 on mainboard
anozira02
Can anyone help me to troubleshoot fuse issue on my Epson R1900? after installing print cartridges accidentally I let of of the flat ribbon cable unplugged and powering up the carriage crashed to the left side of the printer I could hear the gears grinding very loud,,, and that cause F1 fuse blown on the main board. I replaced the fuse with a surface mounted 1mp glass
fuse,, but keeps blowing that fuse each time I power up...I cant seems to troubleshoot this problem.. I could use some help,,, anyone????
anozira02
Have no way of knowing what amp fuse is on board, it's a soldered inboard fuse.. I had similar issues on my epson r1800 and it took a 1mp fuse, fact both board have interchangeable power supply boards with a 2amp fuse.. I have the service manual but Epson is not very helpful giving you information you would need,, other then how to take the printer apart..
