error code 0110 on sp-300v?
Discussion in 'Roland' started by Tim, Mar 22, 2010.
  1. Tim
    Tim New Member
    20
    Would any one out there know what the 0110 error code on a Roland sp-300v would be? I have tried since friday for a "Roland Tech", and have found one person who is able to come out to service it "After work." This is from a ?reputable? sign supply co that I bought this machine from 4 years ago. My shop is in central Ma. I have had Cammtech service the printer before but apparently they no longer exist. Any help would be much appreciated.
  2. SE SignSupply
    SE SignSupply Member
    328
    Start with cleaning the linear encoder reader and strip.
    From Roland:
    Read error of Linear Encoder
    Read error of Encoder on Scan Motor side
    Wire is not attached properly to Head Carriage,
    wire slips, print only machine
    1) Confirm whether Encoder Scale is between the slit of Encoder
    Module.
    2) Clean Linear Encoder strip and sensor.
    3) Confirm Connection between drive wire and head carriage.Print only
    machine.
    4) Confirm Cable Connection between Linear Encoder Board and Print
    Carriage Board.
    5) Bad scan motor
  3. Gino
    Gino Premium Subscriber
    28,712
    573
    113
    Jun 7, 2006
    PA
    Welcome from PA..................................
    They should be capable of talking you through fixing it yourself.
  4. Tim
    Tim New Member
    20
    Thanks Guys! Cleaning the encoder strip did the trick!
