Expanding into vinyl cutting, need help
Discussion in 'New Member Introductions' started by peaches17113, Mar 10, 2006.
  1. peaches17113
    peaches17113 New Member
    4
    Hi,
    Have small home based embroidery and heat transfer business and am going to venture into vinyl cutting. These lists are great, have been learning from heat transfer list and they sent me over here to find more info about cutting. Have Corel 11, am researching which vinyl cutter to buy so am open to any suggestions. Looking at Roland GX-24, but need something that is very SIMPLE to use at my age, lol. Going to Atlantic City ISS show hoping to buy one cheaper at the show.
    Elena
    peachescorner@hotmail.com
  2. Cadmn
    Cadmn Very Active Member
    2,859
    roland I believe is only one to cut directly from corel so that helps on needing to guy more software they are simple to run once you get corel & them figured out. It took me about 30 minutes, there's a few simple things to make it work.I 'm sure they are in the Roland thread. If not just ask .
  3. signage
    signage Major Contributor
    9,242
    31
    48
    Oct 5, 2005
    Penn
    Graphtec C3000MK2-60 24" cutter comes with quickcut that will cut from corel. I have one and I'm very satisfied.
  4. Jackpine
    Jackpine Major Contributor
    cutter
    Ditto with signage. I have a graphtec 3000 MK2 I cut vinyl and contour cut printed graphics. They can be had for around $1,500.00 at SSK. I've had 2 Roland cutter PNC 1000 and a GX-24) and I can't complain but I really like this one much better.
  5. ENTDesign
    ENTDesign Very Active Member
    1,050
    Welcome to Signs101
