FC-8000 Cutting Force
Sagan4862
Seems no matter what i change the cut force to the plotter will not cut through the media. Im using 3m IJ680CR-10 Comply. Currently i have the force set on 20, it seems like it cuts better in certain areas and just scratches the top in other places. Is this an issue with one of the settings or something to do with the blades?
Thanks.
boxerbay
Sounds like you have the blade sticking out too far.
no - he does not have enough blade out.
force is the force of the downward pressure not the depth of cut. you can fudge some additional depth by increasing force but you will run into problems on some fine detail cuts.
we run force 17. what you need to do is increase your blade depth by turning blade holder clockwise one notch at a time and make test cuts until you get a clean cut.
signage
I thought he said it was cutting through the liner! my mistake.
