Fellers POPup
Letterbox Mike
We started using Fellers POPup material a month or so ago, we've sent about 25 banner stands out the door using it. On all of them, we used the regular POPup material, waited a minimum of 24 hours to laminate, and laminated with Lamex 3 mil luster embossed polycarb laminate (the same as we have done hundreds of times using Sihl POSpro 200). We've had 3 come back so far with fairly serious delamination issues, clearly from being rolled up in the retractable banner stand base (we've used 3 or 4 different stands from different manufacturers).
Has anyone else ever had this issue? We switched to the POPup because of the rave reviews here, it prints beautifully and is significantly cheaper than the POSpro, but if it's not going to hold up and can't be laminated it's not worth anything...
bayviewsignworks
Why would you laminate a popup banner?
Scott18
We have never laminated pop-up banners either. I am not sure why you would want to laminate them unless you have scratching issues? What machine are you printing these on? What kind of ink? Is it the same printer and ink as what you used to use? When the laminate comes off is the ink coming away with it? If so then the ink is failing to adhere to the new material. But if the same lam you used before is no longer sticking to the same ink you used before... well that doesn't make sense to me.
