Suggestions Fibron Heat-Transfer Vinyl on GORE-TEX Rain Gear
SignMan17
Anyone have experience with Heat Pressing GORE-TEX rain gear? I have done some research and it has led to more questions than answers. The Fibron heat-transfer vinyl says it works with polyester but I am not sure if the outer layer will be damaged by the heat needed to press the logos. The outer shell of the jacket is described as Polyester Laminated 300Dx150D and the GORE-TEX material is the insulation layer on the inside. I have considered dye sublimation also, but still not sure if it can take the heat. Embroidery seems like a bad idea because it is not guaranteed to stay water proof over time. These jackets cost $300 so I can't afford to buy one for a test like I would normally so any advice would be appreciated
Sign Man
signage
Most Gore-Tex outer wear also have a coating on the outer shell! Also not sure how much heat the Gore-Tex membrane can take.
screener24242
screen printing with either a silicone or HSA ink, possibly with a 2 part catalyst. you can wipe off the outer coating with an acetone. Your other options will not adhere well.
