Firmware Upgrade
jason91
Is there a real benefit of upgrading your printers firmware? How do you even find out if your firmware is up to date? I haven't upgraded in years? Doesn't roland have a site your printer firmware updates...Only thing that seems to get updated is versaworks
excelerator
Ask your service tech to install the Peck utility. You can use that to install firmware updates, which you can download from rolanddga.com/support page for your printer.
Sent from my Nexus 6P using Tapatalk
Ragnabrok
the firmware updates are executable files, the printer needs to be off on the front. You can see what the current firmware version is by double clicking on the printer picture in versaworks, or through the printers menu/system.
Firmware updates can offer improvements, one was to reduce the frequency of re-inserting cartridges on the vs so they don't fail, one corrected the cleaning cycle on the VS to stop white retracting in the lines, sometimes they add support for new inks or retrofitted newer parts like pumps on the pro 2 and motor on the VS.
