first cut wave FC8000
reppert
Greetings,
Has anyone had the issue with the starting cut having a hump/wave for less than a 1/16" then cuts everything right after. Then the next item does the same thing. For example the box and triangle test but its only the starting cut on the box that it happens or if I cut out an R it is the outer cut that shows it but not the inner part of the R.
Tried everything but no difference and also it is consistent so if I do row of test prints the same effect happens on everyone.
Any help will be greatly appreciated.
