Flex face wrinkle
Josh Kuper
We pulled flex over an old frame and used screws on the back of the frame to hold the flex. There's a few little wrinkles on one bottom corner and bottom middle, It's pretty cold outside. It was nice and flat when we pulled it but after we installed it in the pylon frame the wrinkle happened, someone said to use heat but I don't want to make it sag more by heating it. I have a heat gun and some BernzOmatic heaters. Any advice on heat?
d fleming
Heat's not going to fix lack of tension. If it is not an adjustable frame setup for flex face you will have to remove screws and re-tension. And pray. Proper way is to use one mount in middle of all 4 sides and tension to 4 corners.
