Flexi and Mimaki print/cut
Discussion in 'Flexi' started by Beatnik1065, Feb 22, 2012.
  1. Beatnik1065
    Beatnik1065 New Member
    10
    So I recently purchased a Mimaki CG-130fx to go with my Mimaki JV3-160s. I'm currently running Flexi 10.5 and have no problems with the printer. However I'm having a hard time with printing something and than cutting out out on the plotter.
    If I try to add the job to the plotter it says 'Cannot move job because of different setup'
    Any ideas would be helpful
  2. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,622
    9
    38
    Feb 27, 2007
    World
    I belive you have to use Mimaki Fine Cut, it's a plugin for Illustrator
  3. Freese
    Freese Member
    410
    1
    Flexi 10.5 should support both
  4. SightLine
    SightLine Premium Subscriber
    You do not need fine cut at all. Check that the cutter is setup right in production manager. I check back in here in the morning.
  5. SightLine
    Ok - I'm assuming you were already printing fine on the JV3.
    Again - you do not in any way need Mimaki Fine Cut if you have FlexiSign Pro. First make sure the cutter is connected to the computer via USB and you installed the Windows drivers for it and Windows sees it in Windows Device manager. If so load a scrap of anything in the cutter then in Production Manager add the cutter as another setup, if it gives multiple USB ports like USB001 or something you might have to pick one to begin with. Once it's there and has a check you can right click it on the line that is checked and try to send a test cut. This part must work. If that works then it's just a matter of setting the Default Job properties. I always had the "cutter options" button all shut off and set those from the cutter itself. Other then that - back in FlexiSign open something, click it and add a contour cut. Click it like you are going to print, should be a cutter tab on the Rip and Print dialog box. Make sure the registration mark is (going by memory on this as I do not have a Mimaki CG-FX cutter anymore) set to Mimaki type 2 and it is set as "send as separate jobs". Should print and the cut job should be sitting in Production Manager with a hold status. The load the print on the cutter, align it to the first mark, then send the job from Production Manager. It shoudl find all 4 corners and cut away.
    • Like Like x 1
  6. Beatnik1065
    10
    Thank you very much for the quick reply.
    As of right now I can print fine. I will try your suggestions and post back here...
    Again thank you very much
  7. Beatnik1065
    10
    Figured it out.... Thank you very much. Problem was the contur cut and it's "mimaki type 1" marks. Didn't need fine cut at all.
