flexi and versaworks prefcutcontour
shaunie44
anyone advice how to see precutcontour in versaworks please , done a design in illstrator and added the prefcutcontour versaworks sees the 2 cuts but only as contour
equippaint
You have to make the perf cut contour a spot color and name it PerfCutContour then in VW you should see perf cut controls under cutting options. Might have to click enable advanced settings, I don't really remember.
crny1
One spot color has to be named CutContour and the other PerfCutContour so it can distinquish between the 2.
equippaint
Make sure you are calling it "PerfCutContour" case sensitive If the perf cut settings dialog isn't available in VW than chances are your spot color is not named right
shaunie44
its coming up with the 2 dancing lines in versa works but not the second special items A just shows countour cut and 2 sets of dancincing lines
