Flexi / Caldera?
Discussion in 'General Signmaking Topics' started by koz, Jul 12, 2018.
  1. koz
    koz New Member
    17
    Jun 30, 2016
    Novi, MI
    Does anyone know if you can take a print and cut file that was made in Flexi and print it with Caldera?
  2. Solventinkjet
    Solventinkjet Former Merchant Member
    3,340
    568
    113
    Aug 2, 2011
    Denver, CO
    I don't think it will take a native Flexi file but if you export it as an EPS or PDF, it should work like a charm.
  3. AKwrapguy
    AKwrapguy Active Member
    969
    275
    63
    Sep 6, 2014
    Anchorage, AK
    Not sure about the contour cut but you should be able to save as a .pdf and it should work.
  4. koz
    koz New Member
    17
    Jun 30, 2016
    Novi, MI
    Thank you both - it's the contour cut that I'm worried about.
  5. Solventinkjet
    3,340
    568
    113
    Aug 2, 2011
    Denver, CO
    Most RIPs these days use the standard CutContour spot color to designate the cut path which is exactly how Flexi does it when you use the contour tool. So if you want to be sure, ask Caldera if they support that setup which I am assuming they do because pretty much all of the major RIPs do.
    • Like Like x 1
  6. ChrisN
    ChrisN Member
    224
    15
    18
    Mar 6, 2014
    Denver, PA
    Yeah you can export artwork as a PDF with standard Flexi CutContour colors, and Caldera should recognize that right out of the box. I do it all the time.
  7. bannertime
    bannertime "You guys do banners, right?"
    1,158
    263
    83
    Sep 8, 2016
    Arlington, TX
    Since I like making list.
    1. Export in Flexi and choose PDF.
    2. Make sure "Suppress Options" is NOT checked. Click Save.
    3. Select "Full Size"
    4. Uncheck "Downsample..."
    5. Uncheck "Include Border..."
    6. Check "Include Contour Cut Paths" (if this option is not present then you don't have contour paths in the file or they aren't selected)
    7. Click Okay.
    The pdf file will have the contour paths setup with the typical contour cut naming convention that will work in most RIPs.
    For Production Manager users: this is actually a more robust way of importing contour cut files into Production Manager. You can nest multiple contour jobs inside PM instead of setting it up in Flexi. PM will create the cut file with the proper marks. I typically just export right into my PM hot folder to make it faster.
    • Informative Informative x 2
  8. FrankW
    FrankW Very Active Member
    1,037
    53
    48
    Oct 19, 2008
    Switzerland
    It will work. Flexi internally doesn‘t manage cut contours by colour name, but when using the cut contour tool, it defaults to a contour colour which is correctly named for use in third party rips. If unsure, you could select a spot color named „CutContour“ in the design centrals color chooser while applying a cut contour.
    If exporting to PDF, be shure to uncheck „surpress options“ and look if the export of contour lines is enabled or not.
  9. jimdtg
    jimdtg Member
    97
    6
    8
    Jun 18, 2017
    Some places in earth
    I don't think Caldera can open FlexiSIGN's .fs file format. I must export your design to .EPS or .PDF is best way that can be used with other programs.
