Flexi / PhotoPrint 10.0.3 Release
CS-SignSupply
Just received from SAI:
[FONT=&quot]Thank You for all of the important feedback you've sent us about our beta builds! We're about to release version 10.0.3, and we want you to be
the first to know! Without your support, it wouldn't be possible to build such a strong product. We look forward to working with you again![/FONT]
[FONT=&quot]Here is a sampling of the biggest updates:[/FONT]
[FONT=&quot]- Full Fotoba Support [/FONT]
[FONT=&quot]- RGB 8bit Profiling[/FONT]
[FONT=&quot]- Easy Weed Around Groups[/FONT]
[FONT=&quot]- Reduced Install Time[/FONT]
[FONT=&quot]- Cut Overlapping Lines Once[/FONT]
[FONT=&quot]- Stability Fixes[/FONT]
Update Link: http://www.flexisign10.com
CS-SignSupply
Flexi 10.0.3 and PhotoPRINT 10.0.3
Build 1688
8 July, 2011
Improved Features
• Increased size of the Cut/Plot preview area
• Multipage PDF files containing contour cut are now handled correctly when adding to Production
Manager
• Added the Roland SC540 contour marks for Contour without RIP (Option)
• PNG files can now be linked
• The demo dialog will no longer stay behind the splash screen
• The maximum number of copies has been increased from 1000 to 9999
• Added support for the Mutoh SpectroVU for the VJ-1324, VJ-1624 and VJ-1608
• The installation now allows you to choose which help files you wish to install. This will reduce the
total amount of installation time
• Fotoba marks can now specify size, margins and density
• Linked PDF now allows selecting resolution for preview
• Cut/Plot easy weed now has the option to cut around groups and text instead of individual paths
• Cut/Plot now h as the option to cut overlapping lines only once
• Added RGB chart for RGB 8bit profiling. Current devices with 8bit RGB handle ink limit and
linearization inside the printer. During profiling, keep ink limits to 100% and hit Neutral
Linearization
Bug Fixes
• Transparency is now preserved when opening .png files in Flexi
• Linking very large .png files no longer causes a crash
• In Rip and Print the Media list now properly refreshes
• Epson printers no longer feed media when a job that was set to Fit to Media was aborted
• Fixed an issue with Light Magenta in the ink split of LcLmOG color modes.
• Rip and Print now remembers the Registration Mark settings
• Installing older versions of Flexi and PhotoPRINT no longer trigger messages about reloading
font.
• Auto tracing no longer produces jagged results on certain files
• When using the Cleaver Tool, the outline of certain characters no longer disappears
• Fixed an issue with True Shape Nesting that certain paths could not be nested
• Flexi now uses the full space of dual monitors when the resolution of the second monitor is larger
than that of the primary monitor
• Spot_White can now be mapped to the printer white in instances of CMYK+lights
• Closing Bezier paths now behaves correctly
• Using the Cleaver Tool no longer converts other objects to outlines.
• Fixed an issue that some jobs would stay on status Processing when Gradient smoothness was
set to Enhanced
• Objects no longer overlap when applying True Shape Nesting on grouped objects with multiple
copies
• Corrected the display colors of some swatches in the 3630 – Scotchcal Translucent Graphic Film
Color pallet
• Fixed a buffer overrun issue on some systems with Windows7 64bit
• Flexi will default to loading the 32-bit version of Photoshop plugins as the 64-bit plugins cannot be
loaded in Flexi
• Used Colors in templates now scale to the placeholder
• The Rip and Print dialog now reads the color adjustment settings from presets in Production
Manager
• The Twain Acquire scanning dialog no longer displays a “server busy” message when using a
WIA scanner on Windows 7 64 bit
• The Send Mail feature no longer fails when opening files of none native format and sending them
as native.
• On Win7 64-bit system, when printing to non-PostScript printers, the application no longer
randomly crashes when printing designs with lens effect
• In the RIP and Print dialog, the individual color bands can now be selected.
• The contour cut paths generated through Arrange>Contour Cut>Make Contour Cut are now using
spot colors for the strokes
• Poll size now returns the correct values for the Canon iPF6350 and iPF300s
• Fixed a crash in optimize by curve
• Embedded ICC is no longer grayed out for PDF
• The output now matches between Rip and Print and Production Manager for RGB 8bit icc profiles
• Tiled cut jobs that have the auto weld option on will now cut completely
• Fixed an issue with Error Diffusion that sometimes an extra arc shape would be in the output
• Fill plot for letters now works correctly
New Printer Drivers
• Gerber: Solara ION X, Gerber CAT | UV
• Hewlett-Packard: DesignJet Z6200 42, DesignJet Z6200 60, HP Scitex LX600, HP Scitex LX800,
Scitex FB500, Scitex FB700, DesignJet T7100, DesignJet T2300
• Mimaki: JV33-260, UJF-3042
• Mutoh: VJ-1608HJ, VJ-1324 (ValueJet), VJ-1624 (ValueJet), Viper TX Soft Sign, Viper TX
Professional, VJ-1324EU (ValueJet), VJ-1624EU (ValueJet), Viper Extreme 65, Viper Extreme 90
• Roland: VersaCAMM VS-640, VersaCAMM VS-540, VersaCAMM VS-420, VersaCAMM VS-300,
VersaUV LEC-540, VersaUV LEJ-640
New Cutter Drivers
• Aristo: GL 2072-8, GL 2432-8, GL 3232-8, GL 3252-8, GL 4232-8, GL 4252-8
• ArtCreation: ART-630E, ART-630S, ART-630P, ART-1200E, ART-1200S, ART-1200P
• CutterPros: Servo 2400, Servo 4800, Contour 2400, Contour 4800, CR630, CR730, CR1200,
CR1300
• GCC: Expert-24 LX, Expert Pro-60, Expert Pro-132, SignPal RX-61, SignPal RX-101, SignPal
RX-132, SignPal RX-183
• GerCutter-Laser: CT-630, CT-900, CT-1080, CT-1200, CT-630G, CT-900G, CT-1080G, CT-
1200G, CR-630, CR-900, CR-1080, CR-1200, CR-630F, CR-900F, CR-1080F, CR-1200F, CS-
630, CS-900, CS-1080, CS-1200, CS-630F, CS-900F, CS-1080F, CS-1200F, MC-270, CS-630G,
CS-1200G, DC240, SP Series
• GerCutter: MH-365, MH-721, MH-871, MH-1351, ECO Series, PRO Series, CSV1350, CSV720
• Goldcut: JK-721, JK-871, JK-1101, JK-1351
• Omnisign Plus: PRO 600S, PRO 1200S, PRO 600S (U), PRO 1200S (U), PRO 600, PRO 1200
• RF(GER) Cutters: DC-240, DC-330, MH-365, MH-721, MH-871, MH-1101, MH-1351, XL-1.0, XL-
2.0, XL-3.0, XL-4.0
• Saga: SAGA-360I, SAGA-550I, SAGA-720I, SAGA-1350I, SAGA-1600I, SAGA-2100I, SAGA-
2600I, SAGA-360II, SAGA-550II, SAGA-720II, SAGA-1350II, SAGA-1600II, SAGA-2100II, SAGA-
2600II
• Vicsign: HW330, HW630, HW900, HW1200
• Vinyl Express: R19, R31, R44, R48
daveyz52
don't install it if you use Banner 2 settings with a Valuejet 1604. they reversed the resolution:
should read 540x720
instead it reads 720x540 and won't print correctly. most people use G2 settings from what i read, but the majority of my custom profiles are B2.
I put a call into Flexi last Monday. they confirmed the problem and said they're going to fix it, but i still haven;t heard back.
