Flexi Sign and Versa works
Pajdeg
Having problems with Color out put create design in Flexi when sending to versa works colors are washed out can this problem be fixed? I like using flexi I get great color but my contour cuts go off kilter. Do I need to sacrifice color to get files to cut correctly. Thanks to any one that can help me out.
Patentagosse
Are you designing in RGB or CMYK?
You'll get better output from RGB.
? 'Never really had issue in CMYK as for vector elements... for pictures yes RGB is more appropriate. I use Flexi + VersaWork a while... if you need help, you must provide more details, pictures of your outputs, profiles used (in Flexi AND Versawork)
