FlexiPro 10.0 or Adobe Illustrator CS5 Question?
Discussion in 'Flexi' started by jestoker723, Aug 28, 2012.
  1. jestoker723
    jestoker723 Member
    48
    Jan 19, 2012
    Lawrenceville, GA
    I need to find out if the window sticker can be cut to the contour of the design. I've attached the design. I'm new to Flexi and Illustrator. The design has a box around it and I want to be able to cut the shape of the sticker out. Any help would be appreciated.
  2. Scott Reynolds
    Scott Reynolds Active Member
    828
    Select the design and click."contour.cut" in flexi. Do some testing till you get it working the way you want.
  3. rjssigns
    rjssigns Major Contributor
    4,329
    225
    63
    Jun 4, 2007
    Home Office
    In Illustrator you would use Offset Path. Then stroke that path with whatever color your cutter recognizes as a cut contour. Easy Peasy. Another way is to copy and paste directly behind the original, delete all color then stroke that copy with a cut contour approved color.
    Usually when we do decals the bleed is a solid print behind them. That way even if your contour cut is off you will never see any white edges. For the few pennies extra in ink it will always pay off.
  4. thewood
    thewood Very Active Member
    1,781
    Dec 28, 2005
    Tennessee
    This can easily be accomplished in either software. In Flexi, you will need to Ungroup and then Unmask the artwork to get rid of the "box" around the vector artwork.
    I agree that you will want to add a thin red outline for bleed prior to cutting.
  5. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    15
    You probably want to add it prior to printing :thumb:
Similar Threads - FlexiPro Adobe Illustrator
  1. easystar
    4
    540
  2. Chuck7772
    Suggestions Discussion Question New Product Adobe Dimension
    3
    252
  3. WildWestDesigns
    31
    891
  4. Will308decals
    18
    930
  5. GeeProcessor01
    12
    541
