font id please
Discussion in 'Fonts and Typography' started by binki, Jun 16, 2012.
  1. binki
    binki Very Active Member
    1,421
    9
    38
    Jul 23, 2007
    The PRC
    some of it looks like athletic type but other parts are not.
  2. SignosaurusRex
    SignosaurusRex Major Contributor
    8,328
    352
    83
    Mar 7, 2007
    Washington State
    No matches from here. I seriously doubt its a font. You could recreate it or replicate it starting with SCRIPTEK, ROBOTIK or possibly SQUARE SLAB SERIF 711
  3. binki
    1,421
    9
    38
    Jul 23, 2007
    The PRC
    I was kind of thinking the same thing. Thanks for the references to work it out.
  4. DazzaBling
    DazzaBling New Member
    15
    looks like it was poorly traced at one time which is why it may be hard to identify. i say
    retrace it and clean up the nodes and it should be fine.
  5. binki
    1,421
    9
    38
    Jul 23, 2007
    The PRC
    Thanks, I took one of the close fonts and converted to curves and then moved the nodes. The 'artwork' consisted of a printed sheet of paper and an embroidered hat I took a photo of. I noticed while doing this the center of the lettering is to the right of the I in the center. Oh well, it isn't noticeable unless you measure it.
  6. Shovelhead
    Shovelhead Major Contributor
    10,882
    15
    INTRAMURAL ROUNDSTROKE is only slightly off.
