Font Please???
Discussion in 'Fonts and Typography' started by Shovelhead, Nov 11, 2005.
  1. Shovelhead
    Shovelhead Major Contributor
    10,882
    16
    I'm clueless.....
    :thankyou:
  2. slappy
    slappy Very Active Member
    3,927
    3
    38
    May 31, 2005
    Earth
  3. HSG
    HSG Guest
    I've never even seen that before.
  4. Fred Weiss
    Fred Weiss Merchant Member
    20,923
    546
    113
    Sep 11, 2003
    Olympia, WA
    A couple of tips on getting fonts identified ...
    1. Post a sample that is a decent size, in the range of 600 to 800 pixels wide.
    2. If it's a digital photo, take the photo from a squared up perpendicular position to reduce distortion.
    Doing these two things allows for an automated search against more than 35,000 saved samples and will often get the correct result with only a minute or two needed to run the search.
  5. Shovelhead
    10,882
    16
    Sorry....
    only have a low res. from a customer-supplied print out.
  6. Fred Weiss
    20,923
    546
    113
    Sep 11, 2003
    Olympia, WA
    It's not the resolution that's the problem ... it's the distortion.
    I ran a comparison of just the "S" in "Shop" which appears relatively undistorted and it came back with a No Match result.
  7. Si Allen
    Si Allen Very Active Member
    2,146
    1
    Duhhhh....the "S" is upside down! same with the lower case "s".
  8. Matthew Gerber
    Matthew Gerber Member
    28
    Found It!
    Disregard the below drivel.
    The font is Maranallo. Find it here, about halfway down the page, left column:
    http://www.fontface.com/fonts/m.html
    <drivel>I have that font at the shop. However, I can't remember where I found it, or the name off the top of my head. If no one else can help, I'll try to post first thing Monday from the shop and let you know what it is.</drivel>
  9. Shovelhead
    10,882
    16
    Nice...........
    Thank You everyone!!
    :Coffee:
