Gerber Sabre 408
Discussion in 'Laser Cutters' started by Signworks_WI, Dec 15, 2010.
  1. Signworks_WI
    Signworks_WI Member
    29
    Apr 19, 2010
    Hartrford, WI
    Our sign shop is looking at purchasing a Gerber Sabre 408, we just recently purchased the Ion X and are now looking to branch out even more. Right now we have a lot of possible uses in the shop, and can see other uses to try and up sell to the customers. Anyone have one or have used one? Any thoughts on it. We thought about the M series but a little out of our price range at this time. We are going to look at one tomorrow and I have some questions I have prepared for that visit, but am just wondering about anyone thoughts!
    Thanks so much!
  2. The Equipment Guy
    The Equipment Guy Member
    222
    Excellent machine, nothing bad to say about them other than do not ever consider a tool changer, but otherwise a great machine.
    The vinyl cut blade is a waste of time too, routers are just not cut out for vinyl cutting.
    The V-carve bits are a bit pricey, make sure they though some in if you do get 3D autocarve.
    Thats all I can think of for now.
    Craig
  3. Dropout
    Dropout Member
    83
    Did you buy the 408?
    I've had one for almost 2 years. It's a pretty decent machine once you get to know it's quirks.
  4. signdog
    signdog Member
    32
    We've had ours for over 8 years. No trouble so far. A real reliable, accurate workhorse. You will need 3 Phase power or a Phase converter. Buy one with a vacuum table and at least a 10 HP pump. We have the mist option, but find cutting solid aluminum is just too messy. Buy one with a "spindle", not a "router". They take up a fair bit of space and are noisy, but I wouldn't be without it...
    [​IMG]
  5. Pacific Sign
    Pacific Sign Member
    36
    Jul 14, 2008
    Hawaii
    We have one and it's a great workhorse. No problem's so far (we've had it for just over 6 years). I highly recommend it. If you have any questions or problem's down the road, I'd be happy to help you out.
  6. johnnysigns
    johnnysigns Very Active Member
    1,144
    2
    38
    Nov 3, 2004
    East Coast
    Total workhorse, but the lack of a tool changer and no crossover between the Mseries knives is an issue for us. For what it does it's a pretty solid setup though. If we were in the market for one now I'd look at something totally different personally.
  7. Signworks_WI
    Signworks_WI Member
    29
    Apr 19, 2010
    Hartrford, WI
    We haven't purchased one yet, looking for a deal on a used one. Been doing some research and found we didn't have the space, we have recently expanded a bit with the idea that we will have one one day hopefully soon, so if anyone hears about a used one! We woudl be interested!
    Other than cutting shapes and the normal projects what other projects have you used this pieced of equipment for?
    Thanks!
  8. robwaterman
    robwaterman New Member
    22
    I've made furniture with it. Shelves, tables, desks, chairs, Cut plywood, board lumber, MDF, 3mm komatex cut with the 90degree autocarve bit, a 5/32nd bit and some PVC cement lets you build all sorts of cool product prototypes. that can be folded and set into one another.
  9. RSC
    RSC New Member
    15
    Anyone running ProfileLab to drive their Sabre?
    Having trouble getting it setup on our 408.
  10. Dropout
    Dropout Member
    83
    No, but the Sabre is an odd animal.
    Will ProfileLab output G-code?
  11. RSC
    RSC New Member
    15
    Yes it will do G-Code
    I was going to try that next
  12. Dropout
    Dropout Member
    83
    Be careful with G code on the Sabre. While it will run reasonably well, there are some odd things, for instance it won't do a simultaneous G02 or G03 and a Z move.
    I have some nice slots cut in my table from playing with it. :)
    What firmware version are you running?
  13. Inspire
    Inspire New Member
    4
    Helo Dropout
    We are running Gerber Omega on the 408. Im thinking of running Artcamm or Vectric on the Gerber 408. What are your thoughts for v carving and 3d machining.:smile:
  14. Techman
    Techman Major Contributor
    8,519
    8
    38
    Jun 24, 2003
    michigan
    A good cnc machine should not be used as a glorified jig saw.
  15. Keith Jenicek
    Keith Jenicek Member
    44
    We run the Gerber Composer & Artpath programs to operate our 408. Ditto Signdog.
    We also tape a piece of paper to the vaccuum. It will flap when running. It's hard to hear it running with all the noise and ear protection.
  16. Dropout
    Dropout Member
    83
    ArtCAM will work but it's pricey. Vetric supposedly won't but I think it will. I have a PP for Vectric but haven't tried it yet.
    ArtCAM has it's limitations (at least 8.0) as well. It doesn't handle tool offsets like Artpath so it can be interesting to cut out whatever 3d model you've machined.
    I'm running Artpath 5.0 and for anything that it will do, it does it fine. It will not do 3d work though and the nesting is limited to one sheet and one layer which doesn't work for me at all. I regularly run jobs that are 5 or 6 layers and up to 20 sheets of material.
  17. johnnysigns
    1,144
    2
    38
    Nov 3, 2004
    East Coast
    We love using ours as a glorified jigsaw. We're not exactly a sign shop though.
  18. Brad Cairns
    Brad Cairns New Member
    1
    Sep 5, 2017
    7 Barrie Blvd. St. Thomas
    Hey it sounds like you really know this machine, I am desperately trying to find the G codes and M-codes for the sabre 408 router so we can use different software... can you help in any respect with that ? I'm not so savvy with the inner workings of CNC machines... Thanks a million
  19. nolanola
    nolanola Member
    199
    6
    18
    Sep 24, 2014
    New Orleans
    Hello.
    we recently bought a Gerber Sabre 404 with the vacuum table and the spindle.
    The spindle control box does not communicate with the router.
    When I'm trying to turn the motor on from the keyboard it beeps and shows "I/0 spindle fault".
    But the spindle starts from the "direct mode" (opposing to the remote mode).
    Does anybody know how to troubleshoot that?
    Thank you.
  20. JaySea20
    JaySea20 Member
    36
    11
    8
    Mar 30, 2014
    Bossier City, LA
    There is a little program called artspool that is made by artcam. It will allow you to send G code to a 408. I have succesfully routed 3d with it.
