Need Help Graphtec ce5000-50
Discussion in 'Graphtec' started by Rafael, Jan 22, 2019.
  1. Rafael
    Rafael New Member
    6
    Oct 26, 2018
    Lakewood,wa
    Im having trouble with graphtec ce5000-50. The width reads it in length and the length reads in width i can't make the witch longer than 24 since it's the max so when I try to cut letters more than 24 inches I can't make it cut the long way. In smaller things thay are less then 24 inches I have to make everything cut in mirrored so it can cut the right way other than that it won't cut it normally. The plug in I an using is for Corel
  2. asd
    asd Member
    287
    18
    18
    Aug 13, 2007
    colorado
    i am not familiar with that plotter, but may be there is a setting on the machine that will allow you to rotate the page by 90*
  3. Rafael
    Rafael New Member
    6
    Oct 26, 2018
    Lakewood,wa
    Thanks for your advice, I got it to work!
  4. 7oaks
    7oaks Active Member
    509
    3
    18
    Aug 12, 2004
    LOUISIANA
    What plug in are you using
    Ken
  5. Rafael
    Rafael New Member
    6
    Oct 26, 2018
    Lakewood,wa
    Cm 4
