Grouped Outline
KPC
How do you achieve the grouped outline in Corel Draw 12, shown in this thread:
http://www.signs101.com/forums/showthread.php?t=53169
Also, I tried copying the image and using the postcard icon "insert image" but it posts the picture full size. Why is it in the other thread that the image is a clickable thumbnail.
attachment.php
BadAss
You outline in 2 steps, then break apart and seperate. Then you can weld or compine and iy will turn out just as pictured...M*
KPC
Thanks for the reply, I can get each letter to individually outline. however I can't figure out how to group the lettering for a combined outline.
GVP
Effects -> Contour. Set the steps to two, then after applying, break the contour group apart and set the inner one back to white.
iSign
the "postcard icon" will always insert an image that already exists on some web server, right into your post, at whatever pixel dimension it exists as.
Down below the field you type your post into is a button "manage attachments"and this would be where you can upload an image of your own, from your own hard drive, & it will place it on the signs101 server, as well as creating a clickable thumbnail view for it.
KPC
Ok, I was able to complete the 2 step effect-contour process.
I broke the curve. However the contour goes to both the inside & outside of the font. Those two contours still seem to be grouped, because if I try setting the color back to white, or try deleting the inside contour, the outside contour changes at the same time
How can I further break these apart.
Any chance someone can try this in corel 12 and give a step by step.
:thankyou:
signage
KPC in version 12 do a one step outline to get the look you want.
Brake apart and node edit the outline to get ride of inside holes.
Then do another outline of the first outline!
