GS15 plus blade holder help
mdleisure
Hi Guys I am looking for a bit of help with a gs15 plus. i have been printing with the edge 2 and contour cutting with my graphtec but i have got fed up with auto recognition errors so i have finally picked up a second hand gsl5 plus plotter.
I got 3 blade holders with it, one of them is the pen, one is the perf wheel and the other is what i assume is the swivel blade holder but here is where I have run into problems.
It has the screw cap but its not plastic as the manual says its metal and has a small grub screw allen key on it.
It appears to be a mix of the tang blade holder and the swivel.
I managed to get a new blade as I did not get one with it but its from a gsx plus. The supplier says its the same but its pretty loose in the holder unless I use the grub screw to hold it in place. Is this correct ?
My graphtec is magnetic so I dont have this problem. Should it be a tight fit into the blade holder ?
I hope someone has the same blade holder as mine and can identify it. I have not tried it in the plotter yet but if I dont tighten the grub screw the blade will fall out.
Matt
