HELP ! COLOR CHANGE IN PANELS FROM ROLAND VERSAWORKS.
RICHARD SIMMONS
Hi group! I'm dismayed since I don't know what else to do. When I send to print from Roland VersaWorks, to my Roland Versa Art RE-640 large prints with dark background, when installing, it shows difference in the colors of the background. I tried to send them as separate files from Photoshop or Illustrator and the same thing happens to me. I attach photos. Any suggestions?
jimbug72
Not sure if this will fix your issue or not, but I would start here:
If you are letting Versaworks handle your tiling, go to the "Clip and Tile" screen and check the "Place Alternated" box. This will flip every other image so the heat from the apron will be more consistent on the same side where each tile seams.
If you are doing your tiling manually in outside software and loading them into Versaworks as individual images, simple rotate the images so they alternate top to bottom.
