help finding part for seal 54 base laminator
papabud
Lone Wolf
I have a seal 54 and it has a safety sensor.
its an electric eye to shut down the rollers if something to big like a finger heads into them.
well my senor is acting up and needs replaced.
i been looking online for a replacement senor with out any luck.
i was hoping someone could help direct me in the correct direction.
diarmuidrobson
Hi, not sure if you fixed your issue with the laminator but I had the same problem and found the sensor wasn't faulty but out of linement. I ended up disconnecting the right-hand sensor (the one below the control panel) cut the cable at the modular plug and added 4m of cable onto it. Moved the sensor over to the left side and placed the Two sensors about 3in apart. They now have a permanent connection and works without interruption.
