Need Help Help on Summa D140 plotter
Chosen23
One man shop
I am trying to plot something originally designed in flexi, exported to Gerber to use the edge. Then brought back into flexi to plot. Is there a size restriction on material with Summa plotter?
RG
Looks like nobody else has an opinion. So, I'll jump in here. It depends on which Summa plotter you have. I have a D120. I think it plots between 4" and 47.2". Your D140 is larger. If you can print from your version of Flexi, then why not print and plot from Flexi? I do it all the time with my Edge 2 and Summa. And, if you exported the file from Flexi to Gerber software, I don't think Gerber software can put Summa registration marks on the print. Flexi can put the Summa registration marks on the print. Hope I'm not reading your question wrongly.
Chosen23
One man shop
Thanks for the input, one thing I forgot to mention that is it’s a HP edition of flexi and I cannot print to edge from this software which makes it a problem. I did however figure out a way to add the registration marks from flexi save entire job including marks as a .eps for example and then print from Omega, the plot from flexi.
  • Agree
Reactions: RG
