How create Custom Color Palettes in Flexi?
David40
Is there anyone that can tell me if and how to create custom color palettes in Flexi? Can't find anything about it in the help file.
thewvsignguy
Just start on the default palette, edit or add your colors and save it to whatever name you like.
What version of Flexi are you using?
Pat Whatley
Use this....
David40
Thanks for the replies.
Using version 10.5. I did start doing just that, adding my own colors, but then I accidentally changed some of the default colors by accident and can't figure out how to get them back because I don't know what the mixture of colors was. I'd like to create my own palette based upon the default and several others but leave the originals alone in case I screw up again.
Pressing the color spec button allows you to modify the existing palettes but I don't see anything there that creates a new custom palette from scratch.
thewood
Hover over any open swatch table, right click and select New Table. You can drag existing swatches into the new table and add your own colors.
