How to change voltage on gerber edge power supply
Discussion in 'Gerber' started by Will308decals, Jun 10, 2019.
  1. Will308decals
    Will308decals Member
    66
    Nov 1, 2018
    Kearney Ne
    hi, I have 2 gerber edge 2 printers, one with a bad print head that powers up perfectly, and one that has a good print head but just recently quit turning on. With the help of everyone on this site I believe it is the power supply that has gone bad in the good print head printer. The printer with the bad print head has an OHMS # of 1334 and the printer with the good print head has a # of 1448. Which means that the 1334 printer has a voltage in the power supply of 19.4 volts and the 1448 printer has a voltage of 20.2 volts correct? Can I switch the voltage from 19.4 to 20.2 volts and switch over the power supply to the printer with the good print head? And if so how do I change the voltage? Thanks
  2. Hielorojo
    Hielorojo Member
    156
    3
    18
    Aug 24, 2015
    MADRID-SPAIN
    Hello there, you have to "turn" the potenciometer of the Power Supply. You will need a multimeter to check the Output Voltage from the Power Supply and the same time turn the potenciometer, very easy.
    I think that a member "upload" the scheme from the Power Supply, where show the potenciometer and the output where you have to take the measure.
    • Like Like x 1
  3. teddc671
    teddc671 New Member
    4
    Feb 14, 2013
    Guam
    I have the same issue. Can someone upload the procedure again? Thank you in advance!
  4. Hielorojo
    Hielorojo Member
    156
    3
    18
    Aug 24, 2015
    MADRID-SPAIN
    Hello, Send me a private message and I will show as you can do it, very easy.
    Best Regards.
