How to do print dead alignment Oce Arizona/ Fujifilm Acuity
My prints are coming out so blurry, Ghosting, Shadowing. I printed the print head alignment, but can't figure out what to do with the printed info. Does anyone know how to do this? I have the Fujifilm version of the Oce Arizona 460gt. I couldn't find any info in the user manual.
MBO_1
You have to check the printheads. Are they all on the same height ? It is possible when you clean the printheads that you have pushed the printhead upside.
When you have shadow it can mean that one printhead is not at the same level of the other printheads.
The printheads can be pushed correctly back when you open the protection cover.
That was the exact problem. Thanks, worked perfect.
White Haus
Not a Newbie
It's amazing how much of a difference this can make!! I'm glad a tech mentioned this a while back while doing the annual maintenance on our Arizona. Easy fix and makes a big difference.
Sofia Lucas
Blue Dot Signs
Thanks for this kind help, I also need it.:)
jwmurphy
So do you mean the printhead brackets that secure it in place, to loosen those, reseed, and then tighten again?? Or am I missing it.
