how??
josh29j
ok..i have lxi software...and im still learning how to do stuff....how do i take a object in this case a lightning bolt and make it form a arc or complete circle
imaSIGNr
Experiment with your distortion tools...What version do you have ?......Go to your help menu and everthing you need to know should be there.....
imaSIGNr
click file>edit>toolbars, then check all the options you want to have open in your work page. ( distortion ) is under effects. When you have that then click the one that looks like an oval with little arrows in the corner. Your options will show up in design central. Make sure you have that open also. then start playing with it. The help menu will have every description detailed.
