HP Designjet 9000s 64" Large Format Printer, Air Purifier and Dryer Included
JASmith
HP Designjet 9000s 64inch Large Format Printer, Air Purifier and Dryer included
Create long-lasting outdoor signage with the fastest printer in its class. This 64 inch-wide HP Designjet is an excellent tool to boost production and profitability: increase your print volume, improve your services, and reduce your costs.
This printer is in great working condition.
Only used OEM HP 790 and Seiko inks the printer. Has been under a full warranty until last April so it has been well maintained and serviced.
Also included is an HP air purifier/filter and dryer
Asking $6,000 for the HP Printer, Dryer and Air Purifier
Move your productivity to the next level
• Heavy-duty HP printheads and HP supplies for maximum productivity. Experience high-speed printing with six heavy-duty Piezo printheads that come with 512 nozzles per printhead for a total
of 3,072 nozzles. 1000 ml, HP 790 ink cartridges are designed to meet your usage needs.
• Enable long, unattended print runs for improved productivity with the HP Take-Up Reel.
Busy print and sign shop employees can be more productive by maximizing unattended printing with four winding modes: slack/face-in, slack/face-out, tight/face-in, and tight/face-out.
• HP Smart printing technology makes HP ”low-solvent” printing supplies easy to use and manage. Interactive system technology in HP ink cartridges, printheads, and your printer optimizes print quality and reliability and monitors ink levels.
• Dry signs quickly and safely with the easy-to- operate HP Designjet High Speed Dryer. Add this optional high-speed dryer and accelerate drying time. Control temperature, fan airflow, and the timer from the front panel. Combine the dryer with the automatic Take-Up Reel Kit and enable long, unattended print runs at maximum print speeds.
Specifications:
Designjet model size (metric) 1626 mm
Printing
Maximum print speed (metric) 29.9 m²/hr
Print Quality (Colour, Best Quality) Up to 720 x 720 dpi
Print technology Piezo-electric inkjet heads
Compatible Ink Types HP low-solvent pigmented inks
Ink Drop 12 pl
Print Head Nozzles 512
Paper handling
Finished output handling Roll to roll, 4-position support take-up reel
Media Types supported Paper, self-adhesive vinyl, banner scrim, films, fabrics
Maximum weight (rolls) 24 kg
Connectivity
Standard connectivity Hi-Speed USB (compatible with USB 2.0 specifications)
Dimensions and Weight
Dimensions (W x D x H) 2540 x 861 x 1201 mm
Weight 269 kg
Buyer will be responsible for picking up or shipping the printer
