PrintItBig
Hi,
We've just purchased an S2 160T and are perf cutting circular floor graphics.
These are 300mm wide and we're printing them 4 up, 3 or 4 rows at a time, laminating and cutting them in sheets.
The first couple of rows per sheet come out perfect but by row 3 or 4 there are a few where the circles don't 100% join up. They still pop out of the sheet OK but I assume where the cutter does the circle in halves or quarters the cut does't quite match and a little piece of vinyl is left that we're having to trim off with scissors.
Is this normal? Should we just accept it?
Is there a way to increase the accuracy somehow? Do I need to calibrate something?
Would changing the panelling help this so each circle would be cut in one go?
Or adding extra reg marks (not sure how to do this as the option is greyed Caldera)?
Thanks.
Thanks.
