Need Help Ink Cartridge Age Question
player
I have been having new deflection issues. I just figured out how to date the carts and mine are from 2013 / 2014.
I have ordered new replacements.
Are these so old I will have clogging and deflection issues from them?
If so should I do a pump up with cleaning carts?
should I Change out all the dampers?
Any experience or suggestions?
The printer is a VP-540i.
Joe House
If you're having problems, then I would flush the lines (at least the ones you're having problems with) with cleaning cartridges. Pull with a syringe above the damper alternating cleaning fluid and air till the fluid comes through clean and replace the damper. Hopefully this will get you a clean channel.
Solvent inks generally carry an 18 month life after manufacture date. You can fudge that a little but doubling that is probably risky.
Good luck.
Joe
player
Good luck.
Joe
So I need to toss all the inks? That sucks.
How do I alternate cleaner and air? Do you mean every 4" pull out the cart and have 4" of air?
Also can I use generic cleaner over Roland? For half the money they sell 2 times the fluid...
Joe House
Yup, that's how you do it.
If you start introducing variables like "generic" options over OEM fluids, you're playing a game of roulette. If you have time to experiment, you can use whatever you want. I wouldn't.
If you stay introducing variables like "generic" options over OEM fluids, you're playing a game of roulette. If you have time to experiment, you can use whatever you want. I wouldn't.
Exactly. We always recommend our customer use OEM cleaning solution because you literally can't go wrong with it. I have experimented with it and a lot of time the ink coagulates with non matching solutions.
