Installing Vinyl Glass storefront...
Discussion in 'General Signmaking Topics' started by Tony Rome, Mar 6, 2013.
  1. Tony Rome
    Tony Rome Active Member
    516
    7
    18
    Feb 17, 2009
    PA
    Sometimes I spend a little too much time making sure my graphic is straight on a window. It doesn't help I will admit I don't have a great eye to line up just on sight alone.
    I am thinking there is a method (probably pretty simple) that I should be aware of.
    If it is nice squared or text or straight image it is easier, but I seem to do a lot of crazy fonts where there really isn't a straight line to measure or level.
    If I have straight text I would usually measure from the end to the top (or bottom) of window on each right and left side.
    Here is an idea I thought would make it easier, but feel free to shoot it down because I never heard/saw anyone do this, so I am guessing there is a good reason.
    I thought, what if I just created a horizontal line on the very top, maybe bottom too, and just lined it up with that and peeled it off when i am done with the install?
    Any advice?
    Please try to be nice, I realize I may be setting myself up here.
    I will take some abuse as long as it comes with an answer, lol.
  2. HulkSmash
    HulkSmash Major Contributor
    8,159
    140
    63
    Sep 10, 2010
    Denver.
    If you're just installing text, add a box to your text that's centered inside it, and then di-cut that with your text. when you cut it out after masking, use a ruler and cut the the box edge, measure to that.
  3. BelangerSigns
    BelangerSigns New Member
    13
    I do this when i'm doing vinyl on coroplast signs. I just peel back the lining of the vinyl to show the line fold it under then line it op with the top edge stick it, pull the rest of my backing off and lay it down. I don't see anything wrong with what you said. It's easy and quick plus if you know how far up you put the line you can measure off of it. Hope that made sense. Its late lol and i'm done with signs for tonight. Good Night.
  4. Bly
    Bly Very Active Member
    3,067
    372
    83
    Mar 9, 2004
    Sydney
    Put some level marks on the other side with a stabilo then lay a strip of masking tape on it. Easier to align than placing then measuring half a dozen times.
  5. Jillbeans
    Jillbeans Major Contributor
    14,457
    19
    38
    Dec 24, 2003
    Butler, PA
    I usually just draw a line on top of the masking paper with a yardstick and a pencil.
    If you're worried that you don't know where the bottoms are on a curly or crazy letter, just leave the weed border on the vinyl and use that as a straight edge.
    Love....Jill
  6. Marlene
    Marlene Major Contributor
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    take the finished pre-masked vinyl lightly fold in half s and drag a pencil to make tick mark at the top or bottom for a center line. draw a baseline left to right. when you get to the window, measure it and put a piece of masking tape on the glass, mark center on it. it will give you a visual center and then just measure from your baseline to make sure it's straight. if you all ready know the width of the glass, do the math back at the shop so all you have to do is do center, measure one side the distance to figured out at your shop and then just use the basline to make sure it is all straight
  7. CanuckSigns
    CanuckSigns Very Active Member
    3,438
    400
    83
    Nov 11, 2008
    Ontario
    This is what we do, it works great
  8. striper14
    striper14 Member
    285
    15
    18
    May 23, 2003
    home alone
    +1 weed borders rule lol
  9. John Butto
    John Butto Very Active Member
    2,310
    3
    38
    Jan 9, 2007
    measuring
    Never do I measure from the top or bottom of the glass to see if it is level. If the glass frame is crooked, your lettering will be crooked. Use a level.
    Pre draw your line for level as best you can if there are multiple characters and your center line.
  10. anotherdog
    anotherdog Very Active Member
    1,191
    +1 I have seen so many skew and twisted windows. You have a choice; align to the window, the building or the sprit level. All can be different.
  11. xxaxx
    xxaxx Member
    324
    3
    18
    Nov 4, 2010
    Glendale, AZ
    Like others have suggested, just cut it out with a box centered around the text ... Mask then cut out to the edge of the box ... Quick, easy and accurate
  12. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    I do both level and measure. Sometimes a level sign on a crooked window looks funny too...
  13. HDvinyl
    HDvinyl Trump 2020
    2,456
    322
    83
    Nov 20, 2008
    halfway house.
    I thought all installers just burned a J and "eyed it".
    I installed once, but didn't inhale.
  14. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    measure, check with level, check with eye, in that order
    edit: and to answer your questions, sometimes I will put reference boxes/lines, and peel them off after install. I use triangles when I layer.
  15. peavey123
    peavey123 Active Member
    868
    11
    18
    Jul 25, 2007
    Ontario Canada
    haha Nice Av weirdo. jk :tongue:
    I usually just place small squares on either side of the text in the cutfile and use those for alignment purposes. I use the square idea for lining up layered vinyl as well.
  16. johnnysigns
    johnnysigns Very Active Member
    1,195
    4
    38
    Nov 3, 2004
    East Coast
