intel rapid storage tech.?
Discussion in 'General Software' started by ironchef, Jul 5, 2012.
  1. ironchef
    ironchef Very Active Member
    1,293
    17
    38
    May 1, 2012
    Miami, FL
    Hey guys whats this?
  2. Mike F
    Mike F Active Member
    750
    1
    18
    May 11, 2011
  3. choucove
    choucove Active Member
    809
    IRST is basically a driver and software system for Intel-based RAID and SATA controllers. You can recognize SATA and RAID drives in Windows 7 without installing IRST drivers and software, but I use it most of the time because it also incorporates a monitoring system for your hard drive health, and can also monitor and repair your RAID array if you have a RAID system on your Intel integrated controller.
  4. ironchef
    1,293
    17
    38
    May 1, 2012
    Miami, FL
    Ahh intersting... i was saving up for a cheap nas. could i add a bunch of hdd's and raid them? And have sosome ssd's for the rest(system,rip,etc.)
  5. choucove
    809
    Technically yes, if your board supports onboard RAID, you could just put in hard drives and RAID them directly and store directly on your computer. However, this isn't always the best strategy. I recommend offloading. This means take the work and the protection of your stored data out of your daily work computer and place it in a computer or device dedicated solely for that task. First, this will make things more efficient for your storage, as it's centralized and can be protected with higher-quality RAID in a high quality NAS, and second it can be more protected from "daily usage dangers" meaning risks of viruses on your normal computer or possible deletion or corruption. I've also seen quite a few onboard RAID controllers corrupt or lose RAID arrays, so I would not use it for your primary storage. I only use onboard controllers for RAID 1 arrays now when they aren't storing data really, but when they needs always-on capabilities, where they must have access to the computer even if one drive fails. It's not intended as a backup, which I've seen a lot of people set up and do.
    There are a ton of options for storage out there, as you know, but the key really is to begin with offloading the storage to a centralized point specifically designed and handling just that task.
  6. ironchef
    1,293
    17
    38
    May 1, 2012
    Miami, FL
    Oh ok. Yea i figured a separate nas is better. Also i have three pc's in total that i want to centralize storage and do backup. I don't want to spend over 500 dollars for this though. Or at least i cant right now. Ill be in the market for this in a month or so. I have other things i need first. Meanwhile, i have an external hdd i use to back up for now.
