Is this possibele in Versaworks ?
redhot007
Hey
I have printed the artwork and laminated it and started cutting and messed up re cut the artwork but want to skip the previous cutting operations and start where i canceled my cutting process? And it it possible to set the order of cutting operations in versaworks or it will do always how he wants it do?
petepaz
the only way you could do it is if you remove the blade then pause the machine when it gets to the area you want to cut and put the blade back in.
redhot007
Thanks a lot man saved my day ? How is the correct way do do this i will remove the blade start do to the work again and hold down the start button and remove the blade and press the start button again and it will resume?
petepaz
remove the blade once it gets to where you have to cut hit pause and put the blade back then hit pause to resume.
anotherdog
you could also redo the cutline and delete the parts you don't want.
provided all the size settings are the same as the original print.
or as above, but set the initial blade pressure to zero until you get to the place you want. it will only lightly kiss the vinyl.
redhot007
Thanks for the advise seems good idea to test the cutting becouse last time that i did cut the cutting line wondered off so much that the it was unusable. I don't now what i did wrong there.
Cheers
