JFX200 Issue - I'm Stumped!
I am working on a JFX200 and have a weird issue going on. It's a CMYKWW setup. The original problem was the number 8 channel had a Sub Tank sensor error. We changed the sensors and the sub tank. Now we get sub tank overflow errors in channel 8 but there is no overflow. In fact there is no ink in that tank at all. We have determined that ink is able to flow through channel 8 into the sub tank by tricking the machine by swapping the sub tank sensors between the 1 and 2 head. The issue is that because the machine thinks there is an overflow in channel 8, it prevents the channel 8 pump form pumping so it never fills up but it still thinks there is an overflow so it's in a vicious cycle of filling the other 3 channels, erroring out and then trying to refill again. What am I missing!?
humen2
Hi,
Same issue here.
Working with jfx1631 plus.
Ink set mmccyykk nnnnnnnn
On the 8 head (16 channel), having trouble with the ink level, and it's a head that not included in the ink set.
Did you figure out the problem?
Hi,
Same issue here.
If I remember correctly, it ended up being an old filter and bad bottle holder.
humen2
Some parts of our printer is patches that I've made or modified.
By purpose, no air pressure or ink delivered to the right side of the carriage.
What I did today to fix the subtank/slider error was to reset some of the parameters (ink1-flt err/tnk err/spy err/rt err).
Hope it will last!!!
