L25500 Carriage Cable replacement
I have another thread detailing my problems with my L25500. I am replacing the carriage cable assembly, which is all of the printhead ribbon cables. Apparently the top ribbon cables that go into the slots on the board that have the little brown locks are not making a good connecting because the printer is telling me to replace all of the heads, and when I move those cables the diagram showing the heads that need replaced changes. I'm at a loss for what to do, any help would be greatly appreciated
GP_Oz
It is a bit tricky.
The cable conectors are quite small. There is not much margin for error.
The first time i ever did this job i had the same result. Some guys with sausage fingers will hold the cable in square then activate the lock with a small screwy.
It is a bit tricky.
I finally got it figured out after a call to HP tech support. For anyone reading this in the future, you have to make sure the little brown locks are in the "up" position, then insert the cable and flip the locks down towards the PC board. It is opposite of how you'd think it works.
Split76
we changed the whole carriage with the help of service manual downloaded from net.
Romney
This sounds like a nightmare. I'm sure I'll be doing this in the next few weeks. What was the approx, cost of replacement DIY?
