Need Help Laminator issue
Vohaul
So I have a 65” royal sovereign laminator
Which has developed what I call a “wave” which develops over time on the lamination setting.....
Pic here....
Is this just a pressure out of whack setting?
I have a scale and the aluminum strip thing.... is that a result of too much pressure?
What’s the ideal pressure?.
Paul
spooledUP7
Not enough feed tension perhaps. This often causes issues for me, but it may be like Bubba said where your roller(s) are different diameters. If you find this to be true then you may be able to prewarm the smaller section to expand the roller diameter. Just a thought.
Oh, and I have a latex printer which causes this when I haven't let the roll cool down before lam.
Kentucky Wraps
Kentucky Wraps
This happened all the time with my first really cheap laminator (I'll leave the brand name off this thread) and it was because the bottom roller had a different twist in the center compared to the edges.
Solutions are typically,
Replace the softer core...or remove the core and unwind it so it's not twisted. You can possibly do this without removing if you open the nip all the way and un-twist by hand.
Then, to prevent it, as they said above, check the tensions.
