Laminators
Hi everyone, are there any good "US made" Laminators?
heat assist
take up roll
ease of use
kinda something that compares to the CWT Galaxy or similar
jfiscus
Rap Master
I am very pleased with our GFP laminators we have here. VERY easy to learn/use. I am not certain they are actually manufactured in the USA though. I don't see it on their website. We run a lot through ours and haven't had any issues.
*edit - after around 5 years one of the older style heating "bulbs/rods" went out and they sent us a replacement one of the newer style.
greysquirrel
I second GFP. This unit looks like a Kala..they are a bit pricey like 12-15k I believe...I never heard of it before...you should demo the unit before you buy it
karst41
I scrapped my Seal, because I could not get service.
GBC bought Seal and service in my area is through ACCO.
Begged them for a month and told them I did not care the cost.
I need to get jobs out. They did not give one dam about it.
With no storage space for a dead laminator, recycled metal.
Bought a factory re certified Royal Sov, and it needs adjusting due to shipping
so now I have to pay $100 for a scale and a strap and adjust it myself.
WT FK !
The other laminator that I was looking at was the GFP.
The GFP has swing out spindles like the seal pro series.
and you can opt for slitters. and rear take up.
Loading a full roll of lam on the Roy Sov RSC 6500H is a royal pain in the Arse!
This is basically a shoulder high load. Heat assist goes to 128 deg with no adjustments.
It is either on or off. I use a laser and at 95 deg I turn off the heat.
3m specs cold or heat assist between 90 - 100 deg f.
I simply made a bad choice and if I could do it over The GFP with Top Heat assist
is the way to go.
Mimaki has a 62" Laminator for $5800. It is just ok and has very little space
to work in for loading and off loading. A shorter height profile makes easier loading.
Sticks
WT FK !
is the way to go.
Same situation here. I need top and bottom rollers for my 65 EL and all I hear is crickets.
