LED perimeter lighting
Discussion in 'LEDs and Neon' started by All-SignZ, Oct 30, 2012.
  1. All-SignZ
    All-SignZ Active Member
    877
    5
    18
    Aug 6, 2010
    Upstate NY
    Lettering up some windows for a pizza shop and they want LED perimeter lighting around the windows. I'm looking into SLOAN Flexbrite systems but this is going to require cutting/bending the led tubes and wiring everything together. I'm not opposed to doing all that, just wondering if there are better/easier options out there.
  2. Moze
    Moze Very Active Member
    1,829
    80
    48
    Feb 27, 2012
    Dallas, TX
    There are a number of flexible LED strips, but you're going to have rounded corners.
    There are others where you can snap them every inch or so to make your turns. I forget the brand though. Look through the websites for Sloan, GE, Agilight, etc. There are a ton of them out there.
  3. TwoNine
    TwoNine Active Member
    537
    2
    In my opinion - Sloan is a great system for LED Border Tubing. GE Tetra has a nice one too - but all of them require field fabrication. Neither one is easier than the other in my opinion. Have fun!
  4. All-SignZ
    877
    5
    18
    Aug 6, 2010
    Upstate NY
    Ok thanks for the feedback. Sloan it'll be then.
  5. neonlady
    neonlady New Member
    6
    I just heard from an installer / client this morning that Sloan has had some problems with transformers. I haven't had a chance to check it out, but do some checking before you commit.
    Why not use neon?
  6. Edna
    Edna Member
    196
    They sell those a Home Depoe
  7. Matt-Tastic
    Matt-Tastic Member
    297
    1
  8. signage
    signage Major Contributor
    9,207
    25
    48
    Oct 5, 2005
    Penn
    Slone says they have fixed this problem.
