Ledco 30" Laminator Feed table .
packratsigns
Hello,
I have a Ledco 30" Laminator that is missing the front feed table.
It is required to operate the laminator by engaging a couple switches.
I can probably make one with some specs.
Please send pictures of profile etc.
If you have parts please send info.
New ones are about $100 each without pins .
Thanks All.
eahicks
Hello,
Thanks All.
We just made a new one for our laminator, bent a piece of .080" aluminum. We bypassed the switches.
eahicks
Sounds reasonable. Do you have the bend measurements ? Thank you
Here's a quick mockup, the orginal specs and then what we actually made.
edit: note, we left off the 45degree bent part on the rear. and that should be 90degree bend on the front of the original
  • Ledco top.pdf
