Lexan drops - Which side is UV?
Discussion in 'Newbie Forum' started by mattready, May 30, 2012.
  1. mattready
    mattready New Member
    17
    Oct 19, 2010
    colorado
    So we have a ton of drop left over from panels we have cut. Problem is they were not properly marked when they were cut and now they have nothing to distinguish the UV side. :doh: Anyone have a tip/trick to figure this out? Thanks in advance!
    matt@signshopltd.com
  2. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,763
    51
    48
    Feb 27, 2007
    World
    sure
    welcome to signs 101
  3. BIG EASY DOES IT
    BIG EASY DOES IT Very Active Member
    2,021
    72
    48
    Mar 14, 2011
    CA
    Polaroids show up only when light is transfered onto them correct. Black cloth stops light but not UV light. Put an unexposed poloroid under the plexi with a black shirt over top and let it sit outside for a day. If it changes then you know you have it the wrong way. And vice versa.
    That's the only thing I could think of otherwise. Welcome To :signs101:
  4. mattready
    17
    Oct 19, 2010
    colorado
    thats a cool idea. do they even have polaroids anymore :) i was hoping there was a marker or pen or chemical to test with.....hmmmm maybe i should come up with that?
  5. BIG EASY DOES IT
    2,021
    72
    48
    Mar 14, 2011
    CA
    Your other option could also be some sort of test with screen printing emulsion which is also UV sensitive.
  6. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    15
    my only problem with the above steps, is the UV will still get filtered from the 2nd surface down...they only reason for the UV protection is so the face doesnt yellow...I doubt the UV protection is 1-way only
