make decal CutContour linke this -Link to video included
jiarby
install sign cut 2
select object
push the contour cut effect button.
just like in the video
WDP
I CAN do that in illustrator and have more control of path. Ever since we learn to do that it totally eliminated the use of flexi.
GAC05
Quit buggin' me
Add a new layer (to make it easy to select things).
From the new layer select all your overlapping objects
From the Property bar select the "Create boundary" tool to add a single combined path around your objects.
With the new path still selected use the contour tool to add a single step contour to the outside.
Make it the distance you want the offset of your cut-line to be.
Break apart the contour
Delete the inner (original) path.
Done
Should be able to record this to a script and assign it to a single button if you use the same contour offset all the time.
wayne k
guam usa
