mild solvent vs eco solvent for mimaki cjv3 54in.
Discussion in 'Mimaki' started by ironchef, Jun 11, 2012.
  1. ironchef
    ironchef Very Active Member
    1,293
    17
    38
    May 1, 2012
    Miami, FL
    Hey signs101'ers... I've learned alot from this forum, good stuff... i decided to buy the mimaki over the roland. I also decided to go with a dual cmyk setup, now i need to decide on eco vs mild solvent. I know that solvent gets better colors, and that's very important, but health is more important, so I'm concerned on the fumes, we will have it in a 1300 sqft. Open warehouse. No upper level windows for venting soo, I'm guessing i would have to take it up thru the middle , where i have a basic vent, set up for the warehouse. I dont think i can afford the mimaki vent system plus the setup and installation i would need. And i dont think i have an opening to vent thru, any help would be greatly appreciated. Thanks
  2. CS-SignSupply-TT
    CS-SignSupply-TT Very Active Member
    1,541
    1
    ironchef, if you are going to use OEM inks, use the SS21. If FUMES are a concern, ask your HVAC "best friend" for a vent recommendation. I am sure the parts required can be bought locally, including the VENT fan.
  3. Rooster
    Rooster Very Active Member
    1,208
    1
    36
    Feb 22, 2008
    Edmonton
    Since the SS21's contain VOCs, you might be asking for a world of hurt with a straight vent to the outdoors with them. Or maybe not. Check your local regulations to be sure, before you wind with a fine from the local gubbermint.
    Another option is get an inline fan duct and a activated charcoal filter. You should be able to get a system capable of completely filtering the air in your warehouse (depending on ceiling height) for about $1200-$1500 from your local hydroponics store. Set some intake vents up below the printer (the fumes are heavier than air) and it should be more than enough to keep the air fresh and clean and keep the EPA off your back as well. The filters usually last about two years so the maintenance costs aren't too bad.
  4. ironchef
    1,293
    17
    38
    May 1, 2012
    Miami, FL
    Nice, thanks for the advise, been kinda busy these days, how does the mimaki ventilation system compare to getting a local brand or someone to install it locally.
  5. Rooster
    1,208
    1
    36
    Feb 22, 2008
    Edmonton
    A couple of computer fans and some tubing is really all the mimaki vent system is. Unless your dealer is pushing another air-scrubber system on you.
  6. ironchef
    1,293
    17
    38
    May 1, 2012
    Miami, FL
    Hey guys. I've decided on the ss21 inks. But isn't there another option. Like a eco and solvent ink? Also haven't found much on setting up a ventilation system. Anyone recommend a good system i can order online, or a diagram or instruction on making one?
  7. john1
    john1 Guest
    Call Grimco, You can get a air duster 2000 system that is made to vent fumes. Island air makes it and is a industry standard name pretty much.
    It really depends on how much you will be printing on if this system is the best for you.
    If printing just a few hours a day you can get a allerair vocarb 5000 which has a gppd size charcoal filter also to filter the fumes. Pretty much since fumes are heavier than air, the system sucks from the ground into the charcoal filter which grabs the voc's and sends fresh air out the side into the room.
    http://www.allerair.com/air-purifiers/5000-series.html
    The d vocarb 5000 vs the regular vocarb 5000 actually is made for heavy concentrations which means it has a larger charcoal filter which is what you want.
    Don't confuse these with the crappy ones at walmart, The cheap ones charcoal filters aren't even a 1lb and the higher end ones have a 24lb one and even larger. More charcoal the better it traps voc's (fumes)
  8. ironchef
    1,293
    17
    38
    May 1, 2012
    Miami, FL
    Thanks for the advise. Is that the only brand you guys use? My budget is more in the 500 range. All those are 800 or more.
  9. john1
    john1 Guest
    Things aren't cheap, We are only talking a few hundred more and it is worth it. I wouldn't be without anything at all.
  10. ironchef
    1,293
    17
    38
    May 1, 2012
    Miami, FL
    Dale. Ill look into it. I was saving money on the side for media and such.
  11. ironchef
    1,293
    17
    38
    May 1, 2012
    Miami, FL
    They have alot of options. Its confusing. What model do you have and why? And what do you recommend? We have an open warehouse space..1300 sq.ft. no air vents or windows on the walls. Just the vent on the roof. In the middle.
  12. john1
    john1 Guest
    whos Dale? lol
  13. ironchef
    1,293
    17
    38
    May 1, 2012
    Miami, FL
    Lol. Yea im going to call gringo.... i meant grimco.
