Mimaki CG- 160 FX Cutter Blade not engaging or lowering down to material
Gerald Printing
Gerald Printing
My cutter stopped working in the middle of a job. It has never done this before. It still does the program sent to cut the job but the blade is not actually touching the material anymore. The blade does not lower down to cut the sheet so is cutting the program while it is hovering over the sheet. It did make a few weird noises before it did this and it seemed to be stuck and trying to lower down for awhile but not it does not even try to lower the blade down when sending a job or using the Square Cut feature.
Windcalmer
The Branding Experts
That sounds to me like your solenoid is dead. You might be able to check from the solenoid all the way back to the board to check for a break in the wire. I doubt it though.
Are you capable of using a multimeter to diagnose the problem?
Gerald Printing
Gerald Printing
it was the solenoid! we ended up having to get the entire Pen Assembly ($800) and a tech to install it.
