Mimaki cjv 30 130 wont start up
kensign
hi i bought a mimaki cjv30-130 old,was working great.cutting ,but not the printing. The print head is dry out. i try long time and finally got some test print out, then i took off the print head and clean it for a long time with pressure and solution and i knew i blown it. I put it back after clean it , right away show up error code 06 and i turn on and off couple of times. Then the machine went into comma, control panel all dead, won't start up, no power up, no boot , no lights on inside the back all the mainboard ,nothing at all . I know i must have some solution or things on the print head board or leaking and blown it because try to many times, but i potect the ribbons and boards from the print head to the slider board, no damage or drippings, no bending, I knew that,But now only the one led light on show red on the slider board, and the button green light on and when press it has sound, so i think the power on, but not the mainboard, anyone know how to slove it, i diconnect the ribbons from the print head to the slider board or from the slider board to the main board, still nothing. will a new print head make it back to life , it has green light on front but thats it. Please help, so much appreciated
thank you
