Mimaki CJV30-100 Filling Up Problem
DreamPrinter
Hi! I recently bought an used Mimaki CJV30-100, i check every thing and all looks ok. But when i run the filling up option, the pump works but the inks don't fill up the lines. I already clean the nozzle, take apart the head and check if is clogged but no, the solvent runs freely. Please help me because i don't know what else to do. Thx a lot!!
Bulgakov
pump, cap top.
Hello, it is very possible that the problem is in the pump-cap assembly. Try flushing take the cap and see if the pumps suck. See also the head rests correctly on the cap.
DreamPrinter
Hi! thank you for your advice. The heads rest correctly and now i change the Capping tap with a new one but every thing its the same :( I did what you said, flushing and the pump suck the solvent, so i don't know what else to check…
All the lines has air and solvent of the previous clean up, so I'm wondering if i need to fill all it first or use a syringe to suck ink to the dampers?
Thank you again for your help.
