Mimaki CJV30-130 Print head Question
bakaichi
Hi
I was wondering if the Green header print header for Mutoh DF 49684 can be use as replacement for Mimaki CJV30 ?
There is one website that say the DF 49684 and M007947 are interchangeable.
Would any printer Guru help me out. I want to be 100% sure before I start the print head change so at least if is the wrong parts I can still send it back for a replacement
Thank you
Jason
bakaichi
Update...
The Mutoh DF4684 head was able to work with my CJV30 Firmware 3.20
Initially i transfer the OEM head memory over, it would start up and show Head mem1: 128
I switch to a spare Head memory board and was able to start up the printer.
Only thing is ..The head rank id got updated in the printer by it self....
when i try to manually enter the new Head id...it would let me .
But other than that ..is working again
koichi
I used DF 4684 head in CJV 30 before.
The other day, I broke the head and ordered DF 4684 again.
I tried to boot with a new head memory, but I got error 202.
Error 202 when replacing the damaged head.
This indicates that the head memory has been rewritten.
Does the head memory have the number of times of rewriting?
I am wondering if I should order the new head memory E 104428.
Or I would like to know how to change from CJV 30: FW 2.2 back to 3.3.
