Need Help Just In Mimaki jfx200 uv printer
Discussion in 'Mimaki' started by Pagan, Aug 4, 2018.
  1. Pagan
    Pagan Member
    26
    Sep 24, 2014
    Florida
    i just bought a mimaki jfx200 uv printer that it hasn’t print for over 6 month
    But it is connected to power. What problems should I spect ones i turn it on?
  2. Superior_Adam
    Superior_Adam Member
    101
    15
    18
    Dec 13, 2017
    Wichita, Kansas
    I would expect clogged nozzles. The printer should have performed it’s scheduled maintenance since it had power but after not running for that period of time hopefully you can run enough cleanings to recover the nozzles or you may be looking at new heads. I would also make sure the ink is not expired
  3. Pagan
    Pagan Member
    26
    Sep 24, 2014
    Florida
    Thank you ,
    That is exactly what I thought, let see what happens.
    Let see how lucky I get.
  4. Pagan
    Pagan Member
    26
    Sep 24, 2014
    Florida
    The mimaki tech from PDS in Tennessee recuperate the heads
    Flushing all the lines . We put new set of. Ink. Calibrate , boom I’m back on business .
    Thanks Eric from PDS the most knowledgeable mimaki uv printer people
    In the USA.
