Need Help Mimaki JV150 160 system halt 1 1b7 COMIO CN27
Naveed zafar
Sir please tell me how you solved this issue last year
because now I,m facing this issue and still not find anny solution
Or any other now about this issue please share with me
System halt 1
1 b7 COMIO CN27
Sent from my Infinix X680B using Tapatalk
System halt 1
1 b7 COMIO CN27
It means the connection between the IO board and the slider board is broken. Check all of your cables to make sure they are still plugged in all the way. Specifically connection CN27 on the IO board and CN3 on the slider board. Anything that would cause it to not connect like a damaged cable, ink splatter on the cable leads, being plugged in crooked, will cause it to fail. At the end of the day you might have a fried, IO, Slider, or main board.
