Mimaki jv3 160 first hook up
David Obryan
I just bought a mimaki jv3 160 and the cable is a fire wire. My all in one computer doesn’t have a FireWire port. I bought a FireWire to USB adapter but am now getting a power surge error. It’s saying the USB port does not have enough power for the fire wire. Can anyone help me with this
MikePro
If i remember correctly, usb 2.0 didn't exist when they rolled out the Jv3 line, so they went with firewire. I doubt you can run it through a converter since there won't be enough power and i think usb2.0 runs data as packets, vs a stream of data through firewire.
your best bet is to install a FireWire card to your computer, although i'm uncertain if you're able to do that with an all-in-one setup. The only other options would be to either get a computer with firewire, or to try and run it through an adaptor like the DLink Ethernet Parallel Port Printserver and connect to your printer through a network. How to set that up is beyond me, as I'm just relaying some random info from an old thread on this site.
good luck on your new adventure, the jv3 is an awesome machine. i hope you have rip software and/or you got to see it in operation before your purchase. That machine can have a lot of gremlins under the hood if it sat stale for a long time, or wasn't cared-for that well by its previous-owner, BUT if you get it up n' running.... it is a workhorse.
p.s. i also still have my old one in storage, if you're ever in a pinch for parts or a backup machine that really just needs ink lines and printheads to be functional again. mine are definitely rock-solid dried-ink after unplugging it 6years ago :)
